88 v12 starter removal
Ok, so I've changed the starter on my XJSC before, so I know what it entails. What I don't know is what you have to do when you have to change the starter again, forget that the top bolt is a 12 point bolt, put a six point socket on it and round it off. This is where I stand. All of this was done the night before we moved and I had to get it on the moving truck the next day. Needless to say I failed but got it on the truck anyway.
Anyone have a trick or thought for how to get the top bolt out? I know I can beat a smaller socket on, but I can't really get to it. I'm considering cutting a hole in the trans tunnel from the inside. Any other thoughts?
Jeff
Jeff
Received 10,871 Likes
I have a trick for "extreme" problems, but I'm not sure you can do it with this particular situation. I buy cheap sockets and extentions, and attach my welder to them so when you turn the welder on it welds to the bolt. Your clearance levels in there may make this impossible though, so I think I'd use an easy-out socket instead.
I think the tunnel option is the best bet for now. Besides, after you are done and cover the hole, no one will ever know it was there. That is about the only way to get at that bolt. You would have to be able to put a socket with an extension on the bolt and smack it hard enough to force the socket onto the bolt. I have seen some odd looking sockets that can remove stripped bolts. I think they are made by Kobalt and are available at Lowes or on E-Bay. But you will still have to get at them through the tunnel.
Schoe
Schoe
Fixed thanks to Tin foil.
Wow fast forward 9 years and I got the rounded starter bolt out, pretty easily too. I tucked the jag away in the back of the garage and haven't touched it since. It sat back there for 11 years and became a storage shelf for the boxes we accumulated through the new online shopping trend. During the pandemic, I decided to sell some extra cars and crap and dig the XJSC out and get it running again. Apparently it took 11 years for a simple solution to occur to me... tin foil. If I put a piece of tin (aluminum) foil between the socket and bolt head it would take up the slop and break it free. It worked like a charm. In a snap it was loose and the starter was on the ground.
Here is a pic of the head, and side by side with its replacement.
Rounded starter bolt
Rounded next to a good bolt
The following 2 users liked this post by Xjeffs:
leep123 (07-02-2020),
Terje Stendal (07-30-2021)
Wrap the socket
Foil, socket, u joint and extension in place
Mac Allan (07-02-2020),
ssearle
04-16-2014 02:04 PM
TheBrightKnight
07-23-2012 09:14 PM
