88 v12 won't start or crank
Got off of work early and tinkered with the jag a little bit. It currently doesn't have a battery and hooked it up with jumper cables to see if the fuel pump made noise, which it did. Then turned the key and nothing, not a sound to be had(yes I was still hooked up via jumper cables). My question is where I should start looking for possible culprits for the starter not doing anything?
Before you start diagnosing problems the first thing you need to do is to install a fully charged battery.
It takes a lot of current to turn the starter. Unless you are using seriously large jumper cables I doubt the starter is receiving the current it needs to turn.
Put a battery in the car. Then you will know if you have a real problem or not.
Mark
Mark
Received 2,399 Likes
cyber3d
10-27-2015 04:50 AM
Ragn0r
10-26-2015 10:25 AM
