'88 XJS automatic transmission noise.
Is it possible that the road noise I hear in my '88 XJS is coming from a transmission mount that has flattened out due to age and is resting directly on the frame? The noise changes with speed, decreasing all the way down to zero when motion is stopped. I'm currently investigating wheel bearings but I noticed in the CarFax I got with my car that the transmission mount was replaced at 25K miles, The car currently has 92K miles on it. I haven't checked to see what I have for a mount yet. Any ideas?
51rover (03-02-2018),
cat_as_trophy (03-02-2018)
Received 1,442 Likes
. . . and the wonderment will turn to amazement once you retrieve all the small spanners, nuts, bolts etc that fell from above, but never reached the ground!!!
One small addition to Grant's . . . if tempted to disturb shaft for R&R trans mount and/or UJs, first mark all mating surfaces coz balance is critical. Unfortunately, this is one area where you are at mercy of previous owners or a clueless mechanic because incorrect assembly is surprising common.
Cheers,
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
Ken
Cheers,
Ken
The following 3 users liked this post by cat_as_trophy:
Goodo,
Dont forget the loooooooong small plastic tube taped to your Left cheek, the other end in a LARGE bottle of JD, and then whilst admiring Britian's finest, you can "sip away" and eventually it will all be as clear as mud.
Ken is spot on with the marking of things, and take photos, LOTS of snaps, your memory is NOT that good, trust us all on that one.
This might help:
Jaguar TH400 transmission mount explained.doc
This might help:
51rover (03-05-2018),
cat_as_trophy (03-03-2018)
The following 3 users liked this post by Greg in France:
Thanks for the documentation advice. I'm not taking any chances about documenting what came apart on this car. With all it's complications I still love it. Maybe I'm some kind of self-sadist but I definitely enjoy the challenge of beating my head against the wall and still living through it.
Grant Francis (03-06-2018)
Almost.
The JD is firmly glued to the concrete floor, near the shed wall, so I dont knock it A..e up and spill the Necta.
The Mechanics Creeper has 6 caster wheels, and a padded pillow.
Slides sweet under a Jag on 4 of my modified safety stands, and the tube is about 3mtrs long. That tube gets run over too often, and a new tube is needed, must find a better solution one day, but cannot rush these modifications though.
Of course this ALL in the past, since I went on the wagon, but the memories are crystal clear, well almost crystal clear.
Got to ask this, because so many people say so: why should the propshaft be balanced with the transmission and co? The shaft is balanced in itself. If ypu separate the ends (so take the splined end off) then ypu can get an imbalance.
otherwise: why don't the manuals state to rebalance the prop if replaced? Or if the transmission is replaced (happens), why isn't it said to rebalance it all then? Doesn't make sense. And it is a lot more awkward to balance a prop and co fitted to a car than it is to do it outside. You don't balance wheels on the car, but on an external machine, right?
Received 10,872 Likes
Agreed; makes no sense. Never heard of it being done, personally
Daim (03-10-2018)
I've seen on car wheel balancing before, but that is only ever used for super expensive cars with super high speeds, where a nornal tolerance of 0.05g would end up causing massive problems.
bigdreams05
03-01-2007 06:29 PM
