88' Xjs Th400 mph per gear?
#41
Received 10,872 Likes
So, it's no longer "bucking like a bronco" ?
If it has the wrong governor it might shift too early ....but a wrong governor won't cause an engine performance problem. If you have one...which I'm getting confused about!
#42
no yeah it shifts too early. The engine performance feels good to me. This is the only jag v12 I've driven so I wouldn't know if it's lacking power or not but feels like great tq to me. I guess that's my main question... if you try to hold a gear with a lower governor will it not allow it to hold the gear and still want to shift at the lower rpm? Cause clearly the car/trans wants to and does shift like 4,500 rpm
#43
The 400 will make the 1-2 shift *even if you manually select and hold first gear*. If the governor is calibrated to 4500, that's when the shift will happen.
Some 'shift kits' defeat this operating feature so that the trans will stay in the manually-selected lower gear until you move the gearshift ....or the engine blows![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
#44
#45
My 1992 Vanden Plas V12 shifted at 5000 in stock form. The converter is big on the GM transmission, I'm not sure that it can take high revs.
#46
If having a 400 rebuilt for use behind a V12 (or other high output/high rpm engine) it is essential to use the correct spec torque converter. A plain-vanilla unit meant for grandfather's old Buick Electra won't fill the bill!
Cheer
#47
