88 xjs v12 should i bleed
i read Dougs instructions on how to bleed the coolant system.
wondering if this may be my problem. Recently changed power steering pump. meaning i had to remove the drivers side upper radiator hose to the engine. A good bit of coolant spilled out. Once the power steering pump was on i connected everything back up. filled coolant system back up.
Never had a problem with running hot, but ever since this the needle on the temp guage is running above normal. really scary today went to about 1/2 way between normal and as hot as it can get. Hope i have done no damage. i let her cool down for an hour or so AND SHE CRANKS RIGHT UP, wondering if i may need to bleed the system now???????????????
Just my opinion, but yes, you should bleed it. Anytime you break open the system you introduce air bubbles which can cause problems. Better safe than sorry!
As a side note, when I did mine I also added in 2 bottles of Royal Purple Ice Super Coolant additive. My engine temps run almost exactly between the C and the N.
Qgregg (03-23-2012)
should i bleed 88 xjs
ok i got home today jacked up front end, right side 8 inches. drivers side another 5 or so. took of filler cap and resivior cap unscrewed plug on right top side of radiator, cut the heat on high. cranked up the car and antifreeze was pouring out of plug hole. put plug back in while car running put filler cap on ran for a while and is still over heating. any suggestions before taking out thermostat????
88 xjs should i bleed any takers?????
towhe latest after scaling my hand, noticed on the jug of antifreez, which i thought was premixed was not. no clue how this can effect. anyhow let coolant drain out of plug some, filled with water now and coolant.
pretty much needle staying on normal but is jumpping back and forth from top of normal to bottom of normal then back to top 5 or 6 times maybe a hair over N also fan sure is cutting on mighty quick after starting thr car.
any takers??????????
