89 convertible passenger door swap
Evening all, my 89 convertible passenger side door has some corrosion that could be repaired. I have a rot free replacement and wondered how much of a pain it is to swap them over. The glass would need swapping over as well as electrics and other associated door parts. Just trying to get a feel for the best option if anyone has done this job previously. Thanks.
It is doable, Brinny, but quite a pain. Swapping the glass, locks etc etc is Ok once the door is off the car and lying down, but great care is needed to note the sequence of removal/reinstallation. Lock actuators adjustment is also time consuming. The door is removed (in case you have not yet done it) by removing the ankle height A pillar trim and the shin trim under the dash, whereupon you can see two oblong holes that give access to the hinge bolts (I would undo the hinges from the A pillar rather than the door). But the actual door is not the hard part.
Reinstallation is a complete pain, is a two person job, and unless the old door is unrepairably bad I would think very carefully before embarking on the task. You will be presented with the following problems:
I did a door swap (coupe door for coupe door) during my rebuild and never again. Two days and then another day getting the lock mechanism to work properly!
- lock actuation
- glass alignment problems
- door shut and door alignment problems
- door vertical alignment problems
- door to wing shutline problems - which you may only be able to solve by moving the wing.
The stay spring on the hinge of my coupe's driver's door broke so I went about replacing it. Agree 100%. Talk about a can of worms. Never thought about the number of angles and dimensions one has to consider when aligning that thing. There are probably over a dozen. I marked the position of the hinges before I removed the door and it was still a mile off. After probably 3 hours of fiddling with it I got lucky and it's perfect. Doable? yes. Fun? NO.
Plus since each panel on the xjs has a VIN sticker, by repairing the original door you probably retain some kind of value if anyone ever went over the car with a fine toothed comb.
