89 Ignition Switch Bypass
So I picked up an 89 to possibly use as a parts car. However, I'd like to try and get it running to see what shape the mechanical parts are in before I start removing stuff, or decide what I want to do depending on how it runs. The previous owner pretty much destroyed the ignition switch with a drill, does anyone know which wires to connect from the switch to simulate the key being on?
Brown (main power?) Plus white powers all of the interior electrics like the radio, I can bypass the fuel pump relay to get fuel, does anyone know how to manually give power to the rest of the car like the ignition system? Or have a diagram of the wire colors coming from the ignition switch? I've heard that it's brown+white for main power, Black+purple, and 12v+ to yellow/white for cranking (although I can bypass that one by bypassing the starter relay.
It's an 89 US-Market V12 with Marelli Ignition and ABS if it helps
![](https://scontent-iad3-2.xx.fbcdn.net/v/t1.6435-9/254350984_7261656580527031_507467928517950738_n.jpg?_nc_cat=103&ccb=1-5&_nc_sid=825194&_nc_ohc=8YvOaC4dx44AX87L6uH&_nc_ht=scontent-iad3-2.xx&oh=1f52dcad0e90a16c16d4cbcae1fd3871&oe=61AC5CA4)
The following 2 users liked this post by Greg in France:
BuckleSpring (11-08-2021),
Grant Francis (11-08-2021)
Thanks a bunch, I'll give it a shot next time I'm at the car. When I got the car home, I remembered it was Brown to one of the white wires, but in hindsight I may have been jumping White/Pink(Pos1).... Because I remember the radio coming on, but cranking it produced no spark nor any voltage at the TPS (unless Marelli needs to be cranking to send power to the TPS as someone had mentioned, I'm not familiar with the later Marelli cars).
Greg in France (11-11-2021)
m0t0rm0uth
08-19-2023 01:43 PM
m0t0rm0uth
12-04-2009 12:35 PM
