'89 V12 runs like poop unless using 93 octane...
I have to warn you: I may be on the verge of making an ignorant statement, but...
I don't think I have a Marelli car. I've got a single "ignition amplifier" with LUCAS written on it sitting on top of the driver's side (LH) bank of cylinders.
Jess
p.s.: I'm also watching the "my car is idling rough" thread because mine also has a shake when idling at low-rpm that goes away immediately upon adding throttle.
Jess
JessN16 (09-28-2016)
Received 2,266 Likes
You'll see zero difference, not to mention that almost all avgas has lead in it which will destroy the catalytic converters in short order.
Received 10,978 Likes
Make a difference in.....what?
#28
In pre engine management systems that employ knock sensors (aka XJS), there is a minimum octane rating. In these vehicles going to a higher octane fuel will have no effect as the ECU can not adjust timing to take advantage of the increased octane. Even in knock sensed vehicles using 110 will have no effect as the ECU will not adjust timing to that extent.
In the Marelli car Jaguar incorporated an ignition strategy link to have the ECU adjust timing for 95RON. We have 98RON available at the pump but there is no difference in performance in my car between 95RON and 98RON. There is however a big difference between 91 and 95 if I change the link.
#30
Jess
Jess
Change ALL 12 plugs
Check/change all 13 ignition leads.
As a start.
paulyling
12-14-2016 04:10 AM
