'89 XJ-S radio removal?
Can you see two little holes about 1" or so apart vertically on either side of the radio facia ? If you can see them, you have a DIN fitting and need to obtain the two U-shaped special tools that slot into these holes, release the catches and allow you to pull out the unit. However there are other tools which are flat and fit into slots.
Best thing is to visit a car radio/stereo specialist.
