89 xjs dies when put into reverse
Old 12-18-2011, 08:08 AM
worried n confused's Avatar
Default 89 xjs dies when put into reverse
the car has been running great for months after a long slumber. now a new issue has arose, when shifting thr car into reverse the motor will quickly shut off, runs good in all foward gears. I do hear a whistle when going foward. i am assuming it is a vaccumm issue? what do you guys think.
Old 12-18-2011, 08:38 AM
M90power's Avatar
definately a vacuum leak. had the same problem with my old 81 bonneville. in fact id wager its the vacuum hose running to the transmission. others might disagree and say its probably the vacuum hose to the PCM
mbergen
10-23-2019 10:26 PM
PMKimpton
08-03-2019 08:22 PM
tberg
09-07-2015 07:32 AM
SouthernGypsy
09-03-2015 10:54 AM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: 89 xjs dies when put into reverse
