Got the cage mounted, park brake cable (thanks for the tip using the wife to pull on the handle while i pulled underneath), the abs sensors reinstalled, and drive shaft reconnected. All went together smoothly.
to do tomorrow
Put 12l fresh gas in
Paint the radius arm safety strap (i forgot)
Ensure the parking brake adjustment nuts are together.
Put driver seat back in
Hook up battery
Bleed brakes (have speed bleeders in back now)
clean the rear rotors
finish greasing the rear end
Put the rest of the diff cover bolts on
Top up diff fluid
Put radius arm and safety strap on
put wheels back on
Cross fingers and toes
Prey to the old and new gods
turns the key....
