89xjs bulkhead engine wiring looms 1,2,3
I am down to last few things needed before attempting to fire it up. One last question revolves around the 3 harnesses that go into the numbered connections.
Car came to me with then all jerked out, and I am not sure which harness goes where. I have pics that were all I could find on multiple searches.
I do think that I have the top #1 wires figured out due to the only purple wire. The others are not as clear to me.
I would certainly appreciate anyone who can assist in clearing this up. Thanks!
Get inside the car and remove the ankle level trim. You will find three plugs that side too. The wire colours should be the same, so you can match them up. Also, not all the pins are used on each plug, so you can check that the pins used in the wires going in are the same as the ones going out.
Greg in France (06-01-2019)
