90 Jaguar XJS starts cold but conks
Hey guys and gals,
good to see such an active forum.. hopefully ye can help narrow down my problem.
i own a 1990 XJS 5.3L coupe with 66,000m living in Ireland
The car has been in storage the past 7 years and was occasionally driven.
it always started fine first time on the key but lately it will still start first time, when cold and runs for a minute or so then conks. If I try to start it again after it conks it will just keep turning and will not fire up!
I can leave it for a few hours or the next day and same thing...starts first time, runs for a couple minutes, then dies..
It's definitely not the fuel pump as I have put in a replacement pump to eliminate one possibility..
Anybody have similar issues or know the best place to start other than fuel pump?
Thanks in advance!!
Thanks in advance!!
Greg in France (01-22-2019)
This sounds like a possible fuel feed main tank to sump tank problem. The hose gets weak and collapses. I would start by renewing the hose between the two tanks and cleaning out the sump tank and changing the filter behind the spare wheel. Then as part of this blow out the fuel line to the engine bay.
PrinceRandom
19
08-23-2019 10:13 AM
Frank Reynolds
01-23-2019 05:25 AM
sneal46
04-16-2015 10:35 PM
