90 XJR rims
BC XJS (04-18-2016)
BC XJS (04-17-2016)
Received 10,916 Likes
The Jag bolt pattern is 5 x 4.75"....at least until the mid/late 90s.
Better double check what you are getting
BC XJS (04-17-2016)
I believe the wheels you are referring to are Penta's which were first introduced on the 97\98 V8 XJR.
They do fit, but you will need spacers at the front and possibly small ones at the rear. The fronts you'll need at least 10mm (if you canget away with it) if not 15mm.
Hope that helps..
Rich
Hope that helps..
Rich
BC XJS (04-18-2016)
BC XJS (04-18-2016)
Hi BC XJS,
The Penta wheels are working for me, see https://www.jaguarforums.com/forum/x...ls-xjs-142094/
I am using 3mm spacers on the front and none on the rears.
BC XJS (04-18-2016)
webbeing
04-18-2016 11:46 PM
