91 xjs abs
Sorry, asking lots of questions, chasing lots of problems…
With the car off I have a pretty high, hard brake pedal. A few pumps doesn’t really change it much.
When I turn the ignition on, the yellow relay in the passenger knee area clicks, the dash brake light comes on and I hear the ABS pump run, but only for a few seconds, then the relay clicks and both shut off. If you turn ignition off and then back on, neither the light nor the ABS pump runs.
If you apply brakes with ignition on, it does the same sequence as above.
With the key on, the yellow relay clicks twice about every 30 seconds.
When driving, after you apply the brakes, the dash brake light comes on, then the ABS light comes on. just a few seconds and then the Dash brake light goes out and then ABS light goes out.
where do I start???
where do I start???
