92 XJS convertible 12. shimmy in front
Friends. have had the car about 1.5 years. at the beginning just a tad of a front shimmy. then it became much worse. Up to this point I have replaced upper and lower ball joints, new struts, alignment from supposedly best shop in town, new tires, new front bearings. some new bushings where it was obvious, replaced anti roll bar links. Nothing has worked. Now I am thinking could it be the rims? way back I did exchange the two front tires but I did not move the problem. Had purchased for wife as I already have an 87 coupe. It is too the point I don't want to drive it!!!!!!!!!!! Pls help. Jim
Does the problem fade under hard acceleration or moderate cornering? You've thrown darts at everything else but there a few other (somewhat unlikely) things to consider.. Front subframe mounts front/rear and the steering column linkage itself.
We need a better description of exactly what it is doing.
