92 XJS V12 shakedown cruise
I am on another extended cruise with my V12 coupe. Things of been going fairly well. Finally learned how to use the cruise control and I’m just so excited that it works!
It has been raining most of the way. So I have discovered I need wiper motor repair. They work very very slowly. I also have leaks at the front of each door near the hinges coming down over the speakers and onto the kick panel.
One thing that bothers me is how long it takes to get this motor started. It cranks long enough for me to envision it not starting, having to call a tow truck, bring it to a small town where no one understands jaguar repair, and being stranded there for several days before it actually kicks in and starts. Is this something that can be done about extended crank time before start up? I have tried cycling the fuel pump multiple times before cranking me and Chen and that does not seem to help. It also seems worse when the car is warm.
Hi gccch
This sound symptomatic of a failing diaphragm which is inside the FPR 'Fuel Pressure Regulator' on 'B' Bank, which is the FPR on the same side of the Car as the Oil Filler Cap
Don't worry about the FPR on 'A' Bank, as it isn't needed and was eliminated on the later Cars
If the Diaphragm inside the FPR on 'B' Bank Starts to fail, then by default this can result in lowering the Fuel Pressure, then guess what? She could be a nightmare to start
A new one is about £45 (uk) and is very easy to replace but don't do it on a hot engine and disconnect the battery, just to be on the Safe Side
The Other thing that it could be is a Blocked Fuel Filter £10 or a Fuel Pump that could be on the way out £35 so best to start at the Cheap end and then work your way up from there
You can See the FPR on 'B' Bank about halfway down on Page:87 of my 'Cherry Blossom' restoration thread including Pics
Click: on the Link Below to see all the Photos
The FPR on 'B' Bank had a Leaking Diaphragm and had to be replaced
If the car is a 92, then it only has one fuel pressure regulator and it looks totally different from earlier cars. Check it anyway
Were the fuel lines replaced/rebuilt lately? If so, maybe the non return valve was omitted. It will be spliced into the rubber fuel line that runs from the metal fuel line on the inner fender/wing to the fuel rail. If these hoses are old, then perhaps you have a bad non return valve.
But... to be certain either way, t-in a fuel pressure gauge on the high side. Don’t make the fuel pressure gauge a dead end, it has to T off. You can get a cheap Chinese one that will work at least once.
Greg in France (12-30-2018)
Hi gccch
All you need is a New FPR for 'B' Bank which is very easy to put on but don't forget to put the pipe back on the other end of it, as that is the return Pipe to the Fuel Tank
Make sure you do that properly, as if that Pipe comes off, then you could have a Fireball on your hands!
FPR diaphragm failure is a lot more common than you at first may think and can play havoc with getting the Car Started and on my own Car, I've replaced that twice in just 3 years
As for the one on 'A' Bank don't bother to buy a New one, as it isn't needed and if you know what you're doing can be taken out of the Circuit altogether and then just bridged with Top Quality high pressure fuel pipe, or else you can just leave it as it is
I think my 92 has only one of these FPR valves on the passenger side. All hoses are Configured as original (almost certainly). I will replace this FPR. I also trimmed some of the vacuum tubing going to it to attempt a better seal. It seems a little easy to remove. Could be leaking. Thinking I should add a clamp here.
Hi gccch
You could well have hit upon the cause of the problem, as a loss of Vacuum anywhere is a great big No! No!
Where any loss of Vacuum on the FPR could make your Car run rich
So get the Vacuum Pipes sorted out first to make sure that there are no leaks and then see if you find there is any improvement
So I have had some work done and this problem has gone away. New ignition coils were needed to solve intermittent loss of power. Also got my AC fixed and the cats cleaned out.
Car is running and idling very nicely and keeping me comfortable. The FPR had a small leak but the mechanic confirmed it is working properly.
Still cranks for a long time before starting. That really bugs me.
Received 10,979 Likes
How long is "long"?
5 seconds? 15 seconds?
Under any and all conditions?
I've owned some cars that would start on the first spin of the starter. My V12 Jags have always needed a few spins....although not to the point where I'd consider it to be excessive or 'extended cranking'.
Don't take mine as the final word but I'm not so sure about the check valve being a culprit. A healthy fuel pump will re-pressurize the fuel rail almost instantly. Maybe 2-3 seconds at the most......which, coincidentally, is the duration of the "prime" function of the fuel pump circuit on the V12s.
A quick experiment would be to turn the key 'on' and listen for the pump. It should run 2-3 seconds. Turn key 'off'. Repeat this 'priming' exercise 2 or 3 times....which should be more than enough to pressurize the system. Now try starting the engine. If the engine starts quickly, you're on the right track.
I dunno where the check valve resides. But, if the location remains a mystery, a universal check valve could probably be plumbed-in without too much fuss.
Greg in France (01-13-2019)
orangeblossom
03-30-2014 05:29 PM
