93 Air Filter replacement
Old 07-08-2016, 10:23 AM
aaf8's Avatar
Default 93 Air Filter replacement
Is it really this difficult to replace the air filter?
Old 07-08-2016, 02:51 PM
Paul_59's Avatar
Banned
The V12 is very easy to replace air filters .
Not sure about the 6 cylinder engine, helps if you can be more specific about engine in your model XJS
Old 07-08-2016, 06:46 PM
aaf8's Avatar
Default Help
Yes the 12 is pretty easy. The filter box on the 4.0l is lodged between other parts in such a way as to make the job fairly complicated....unless I'm missing something... Added a pic.
Old 07-10-2016, 05:30 PM
ptjs1's Avatar
Received 3,033 Likes on 2,015 Posts
aaf8,
Yes, the AJ6 / AJ16 is a bit of a pain. I (carefully) undo the butterfly nuts on the inner wing. Be careful, it's easy to rip out the rubber mounts! I also remove the air intake trumpet on the top rad valance - that can be a pain in itself. It's then much easier to remove the joint to the MAF and remove the canister.
Hope that helps
Paul
aaf8 (07-11-2016)
Old 07-11-2016, 11:07 AM
aaf8's Avatar
That's what I was afraid of.
Thanks Paul.
klintous
04-15-2022 10:44 PM
AlexJag
05-17-2016 01:00 PM
Gerard Radimaker
05-15-2016 01:41 PM
someguywithajag
04-25-2016 12:04 AM
Jtpytel
04-15-2016 07:14 AM
Quick Reply: 93 Air Filter replacement
