93 xjs 4.0 auto trans light on-Solutions ???
butkusandbale,
Unfortunately, your scan tool won't work with your XJS. You need a Jaguar-specific PDU which plugs into a bespoke port in the boot.
However, you should be able to dump the fault code and light by disconnecting the battery for 30 mins. If the light goes out then reappears, it's because the car has "seen" the fault again.
Hope that helps
Paul
Hope that helps
Paul
butkusandbale (04-20-2015)
