93 XJS Alarm question
Does the alarm on a 93 XJS make the lights flash? All of them? I have a 93 that when shut off, the lights flash for a split second about every 5 seconds. When they flash the light warning buzzer also chirps, as it should, I guess. I did just replace the battery, but I believe this was going on befor I replaced the battery as someone had pulled the side light relay, which controls the tail lights. When I replaced the relay, I found why they had pulled it. I don't feel like pulling that relay every time I park the car. While the engine is running it is fine. Also the lights are all working fine when they are turned on. Could this be related to the alarm? If so, how do you reset the alarm, or disable it?
Thank you in advance for any ideas!
Daren
Daren
