93XJS 4L TPS relacement
well new ones are NLA so I had to get a used one...anything special to install....I see the holes are slotted...just mark where the old ones were and align the used on the same way? Do I have to take it to the dealer afterwards to set anything? If I am supposed to and I dont, any harm?
Yes a newly installed TPS has to be reset to specs., which seem to be .06 volts at idle. I also have to reset/test my TPS and I'm having a hard time finding which colored wires are used to test the proper voltage. So far, I've just set it by ear, it does run, but it is far from correct. Good luck with yours and if you do get any more information about testing and setting the TPS, please post it.
RagJag (08-18-2012)
