94 convertible front speakers not working
OldCoastie (04-13-2021)
You would think that after changing the fuel pump, the wiring harness under the hood, the engine monitoring ECM, the charcoal evap canister, purge valve, EGR, fuel pressure regulator, seals to the fuel lines, fuel filter, two convertible top hydraulic lines, plugs and wires, one tail light and one side marker light and various relays and switches I might be qualified to adjust the fade on my radio. Guess not!
Some times being a little ADD is not helpful. (except when you own a Jag)
Still have front springs and calipers before I paint it.
Brewtech (04-18-2021)
