94 xjs L6 engine,no start
Old 12-30-2009, 03:10 PM
jagman94's Avatar
Default 94 xjs L6 engine,no start
Hi,my 94 xjs L6 engine will not start.Checked for spark,no spark.Checked coil (+) hot post with key on and it is only getting 7 volts from ignition key wiring.Checked coil (-) negative post with key on and it has 7 volts also.I imagine the problem to be coming from the ignition (key) wiring.When I try to start car,starter turns over good. There is no voltage reading when meter cables are attached to coil (+) positive post and coil (-) negative post while cracking engine.Hope there is somebody out there that can help me solve this problem.Thanks,HarryK
SCMike
11-25-2015 07:55 AM
Mac Allan
10-27-2015 04:49 AM
workworkwork
10-01-2015 01:44 AM
redgear
09-26-2015 07:21 AM
Quick Reply: 94 xjs L6 engine,no start
