94 xjs v12 6L
FF45 is a bad O2 sensor, that's not related to no start.
Given the parts you have changed, are you sure that everything is assembled correctly and all properly seated? Wires connected back as they were before? Plugs properly making contact in the coils, same for the wires? All it would take is the lead from the coil to distributor to not be making contact and you have no spark. All the plug wires connected in the proper order? It's easy to get them mixed up.
Have you tested to see if you have a spark?
lovjags (11-03-2017)
