94 xjs v12 recommended part brands
For spark plugs, the V12 likes NGK ones, BR7EF. There is no need to get the fancy ones, the engine seems to like the plain ones better.
I use a mix of aftermarket an OEM parts, depends on what it is. Coils don't seem to matter too much, wires I use Lucas or Denso. For cap and rotor I managed to get a genuine Marelli, not sure if those are still available.
jxjsv12 (07-23-2018)
Most of us go aftermarket but you have to be careful what you're buying these days. Aftermarket quality varies a lot on some items. Best to post here, case-by-case, and hear what others have to say. On certain items, relatively few, genuine Jaguar OEM is favored.
jxjsv12 (07-24-2018)
NGK basically only does plugs and they are what belong in the engine.
Basically every manufacturer grabs into a deep parts bucket and builds using what he can get hold of. So nearly everything has an OEM supplier who will sell without the Jaguar stamp.
For example:
- Balljoints: Lemförder
- Brakes: ATE
- Filters: Mahle/Mann
- Spark plugs: NGK
- Marelli parts: Marelli or NGK (when available)
- Shocks: Boge
After like being around for 40 years, most licensed parts have been 'off license' so aftermarket sales are possible (like with the ball joints). So no Jaguar only parts required.
Just keep in mind, that good OEM parts aren't super cheap. Üro was never OEM. But does do some (!) good parts... But suspension parts aren't quite up high in their quality thoughts.
For example:
- Brakes: ATE
- Spark plugs: NGK
- Shocks: Boge
Agfree with all that has been said.
Only thing I will add is, if you have an original Marelli cap and rotor and they are in good condition keep them, aftermarkets are not as good a quality. I have both and the aftermarket cap I have has flat aluminium posts, original Marelli has round brass.
orangeblossom
03-30-2014 05:29 PM
