95 xjs air conditioning pressures
Old 04-18-2011, 05:56 PM
expedio2005's Avatar
Default 95 xjs air conditioning pressures
Does anyone know the correct operational psi ranges for both the low and high side ports? I've been searching the internet for hours now with no luck.
Old 04-20-2011, 08:41 AM
Idling with the A/C fans on low speed the pressures will be roughly:
28-30 psi, low side
150-170 psi, high side
Kick the fans to high speed:
35-40 psi, low side
190-210 psi, high side
That would be at ambient temps around 75 deg. F, higher temps would mean somewhat higher pressures, and cooler temps a little lower.
Hope that helps.
Old 04-21-2011, 07:01 AM
28-30 psi, low side
35-40 psi, low side
Hope that helps.
Thanks Steve, it's a huge help. I just couldn't find it anywhere, even on my service manual cd.
toronadomike
08-07-2022 03:41 PM
Kevin Burnaby
06-28-2020 08:04 AM
dsnyder586
04-04-2019 02:38 PM
mikelibera
XJ40 ( XJ81 )
09-04-2015 05:17 PM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: 95 xjs air conditioning pressures
