95 XJS Convertible seat cushion replacement
I ordered a new driver seat bottom to replace my old worn seat. I am trying to find instructions/advice on removal and installation of the bottom seat cushion. Do I need to remove seat from the car or can it be done with the seat frame still attached to car? I would like to avoid having to remove the seat as it appears to be quite a frustrating task. Any advice would be appreciated.
I found it at https://gahh.com/ GAHH Automotive. Haven't received it yet but I was also having a hard time finding the base for my car and then this site came up last week on a search. It looks legit. We will see. They shipped it out within a couple days of ordering, arrives on Thursday.
I just ordered a diaphragm from Ebay. Not looking forward to this install. Sounds like a real trick to get the seat out.
Timeisrelative (10-04-2022)
I've always found it fine taking the seats out of my convertible ( as long as the seat motors are working
Move it all the way back and undo the two screws at the front of the runners. Then power it all the way forward and remove the 2 screws at the back holding the runners to the car.
Carefully disconnect the wiring plug and lift the whole (heavy) seat and runner assembly out.
A good time to then vacuum and shampoo the carpets!
Good luck
Paul
Good luck
Paul
Project complete. Thanks for the advice and help. The seat bottom that I was expecting to be a fully assembled cushion and leather turned out to only be the leather. The item description was a bit deceptive in my opinion. BUT the leather was nice and was the right one for my car. I decided to forge ahead. Removed the seat and disassembled without too much trouble. Used my old cushion and a new diaphragm which I got from Paul's Jaguar via Ebay. End result is very good. The leather is a tad looser than the other seat due to the poor condition of the old cushion but it is done now and looks very good. Highly satisfied by the result. Thanks again for your help and encouragement!
The following 3 users liked this post by NHXJS:
Sometimes you can use a steam machine to rejuvenate seat foam and not replace it. Here are a couple of videos on the process.
https://youtu.be/zH-s2ald9HA
https://youtu.be/5rndD6tzZPo
Jon
Jon
A big block of new foam was $40.
I did have to buy an electric knife. $15
I may have had to buy some glue as well. I glued some fiberglass sheet to the slit where the seat support goes into the bolster foam to make sure the bar did not eventually cut through the bolster foam over time. $5.
Vee (10-21-2022)
