95 XJS Face lift 2+2 4.0 trunk light stays on
Jon
The following 3 users liked this post by jal1234:
Captain Bob 369 (04-17-2022)
Captain Bob 369 (04-18-2022)
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Had the car into the shop. Could find no real drain, but car won't start in Park. Shifter cable stretched and switch can't tell it's in park. Their diagnosis is that this could be the problem because car doesn't know it's in Park and some things may not shut off when the car is turned off and the key removed. This is a 95 XJS 4.0 2+2, could this be possible without many computer parts being on this car?
Secondarily he can't find a new cable and is afraid to try and adjust the switch as the cable may break. Cable part number is MHF4930AA, any suggestions as to where to get a cable/
Thanks for the previous replies.
Captain Bob 369 (04-26-2022)
I dont think the car is clever enough to keep different systems active if its not in Park. I've often left mine in Neutral.
As regards the battery drain, connect a multi-meter in line on the battery terminal and just measure the current draw with the ignition off and boot light disabled. f the battery is going flat, there's either a current draw or a duff battery
Good luck
Paul
Good luck
Paul
Thanks, I Agree that this 95 Vintage has no brain to leave things on. The cable is very rusty, reason for not trying to adjust. Could parking brake light or light out warning light staying on have anything to do with it?
The shop could find no drain with meters, left it for three days.
When AAA came to start the car the tech said it only had 100 amps left in it but battery tested good.
Puzzling?
Puzzling?
The only somewhat common power drain on these cars tends to be the power antenna. I would disconnect it and see if that solves your problem.
How old is your battery. I had an Interstate battery that gave me all kinds of fits. Once I finally replaced it, I think two years in, all the little gremlins went away. I think it was just a bad battery. These cars are indeed very sensitive to proper voltage. One way I know my battery is nearing the end is when the power locks begin to work less consistently.
Greg in France (04-27-2022)
Bob,
If the technicians have monitored it over a period of time and found the current draw to be acceptable, then I would:
- Disconnect the battery
- Measure the voltage
- Fully charge the battery (disconnected)
- Leave 24 hrs, measure voltage. If under 12v, condemn battery
- if above 12.5v, reconnect
- Start car whilst monitoring voltage, Perhaps activate inertia switch to prevent starting and allow cranking to run longer
- If voltage drops to below 10v during cranking, I'd question the integrity of the battery
It's not a proper drop test, but it's a good start.
Good luck
Paul
Good luck
Paul
Captain Bob 369 (04-27-2022)
