95 XJS Gauge cluster inoperative
Old 01-15-2009, 08:04 PM
philsk8ts's Avatar
Default 95 XJS Gauge cluster inoperative
Hey there, im working on a friends 1995 XJS 4.0 L6..... The tachometer, speedometer and the erm i believe the... fuel gauge does not work... Wondering if there is a specific fuse that feeds those gauges.... or if ive got a bigger issue... i looked in the book and couldnt find a gauge cluster fuse in any of the fuse blocks... so if anyone has any ideas or such! please let me know!
thanks for your time and help
Phil
Old 01-16-2009, 08:45 AM
Keith's Avatar
Default RE: 95 XJS Gauge cluster inoperative
OK, you asked for ideas, and I'm not real sure, but, somewhere I've read that the grounding for the gages were a problem. The cure suggested was to add a second ground wire from the grounding area to the frame. Anyway, just an idea, at least a starting point. Good luck.
Old 01-16-2009, 08:12 PM
philsk8ts's Avatar
Figured it out..... took the under dash panel out and moved a few connectors around, turns out some dingleberry left the gauge cluster connecter partially disconnected... after 15 minutes of laying on my back with a flashlight in my hand! problem solved! thanks!
phil
jagtoes
09-09-2015 09:56 PM
carcycle
09-07-2015 10:22 AM
1100me
09-07-2015 06:26 AM
giandanielxk8
09-06-2015 07:21 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: 95 XJS Gauge cluster inoperative
