'95 XJS V12 6.0 L Source, make, model, alternator
Seeking any pointers for tracking down the right make, model, acceptable AMPS, (115, 120, even 140-150 would that damage other electronics, modules, if fused?). Have tried all of the usual suspects (SNG, Moss, Welsh, Pauls, and secondaries as well, Jaguar Heaven, AdvanceAuto, Auto Zone...) Even though they show the Jag, Denso, Bosch, CarQuest, Duralast models that claim "this fits," they actually don't! My Mechanic (Jag specialist... or extortionist ;-) indicates need single round back with one eyelet, not two for mounting. I've looked over strings that go way back in time. May be a current (no pun intended) inventory issue. Anyone???
I would ask your mechanic to send you a photo of the alternator so you can compare it to others or even show specialist suppliers or post on here. Alternatively see if you can get hold of a part catalogue for your year of car- check ebay they are still available. As far as I know there was not much changes to the alternate housing when they upgraded to the 6.0L and even the TWR model used the standard factory unit. If you can post pictures then I compare to my catalogue, sadly my copy is security protected so wont let me print off or save any part to PDF.
As always, just go to Jaguar's Parts website first to get the right part number. Here's a link to the late 6.0 Alternator pages:
Genuine Alternator-120 Amp (4.0 Litre,6.0 Litre)((v)from185820) For Jaguar Xjs Sports Coupe/convertible 1975 - 1996 Classic | Jaguar Land Rover Classic Parts
Genuine Alternator Mounting-120 Amp-6.0 Litre (6.0 Litre) For Jaguar Xjs Sports Coupe/convertible 1975 - 1996 Classic | Jaguar Land Rover Classic Parts
Good luck
Paul
Good luck
Paul
The following 2 users liked this post by ptjs1:
Greg in France (08-09-2024),
orangeblossom (08-12-2024)
Received 10,978 Likes
If all else fails have your existing alternator repaired. Most larger cities have a repair shop specializing in alternator and starter repair. In your neck of the woods it looks like this outfit might be one
https://www.autoelectricinc.com/auto...rt-and-service
ptjs1 (08-09-2024)
Just went though this. Every alt I ordered, even when using the correct p/n arrive wrong. As far as I know if you order the 1994 /1995 V12 alt you will most likely get the incorrect part.
Solution:
XJ6 inline 6 alt from the same year is the same, internally. The case is different on the V12 so you can buy a inline 6 version and swap over the internals. If you need help with this as a service DM me
Solution:
icsamerica,
I guess it's just possible that an error has crept into the Jaguar parts website. Jaguar quote the part number for the late 6.0 as DBC6820. If you've got any photos etc that might indicate that the part number is wrong, let me know as I can then call my contact at Jaguar and see if we can get it changed.
Paul
Paul
Greg in France (08-10-2024)
Ah I see! as so often, we're at the vagary of suppliers, other than Jaguar, to actually get it right. I guess that's the challenge we always face of trying to avoid paying the often very high cost of purchasing direct from Jaguar.
Coincidentally, I notice that SNG are offering DBC6820 on a reconditioned exchange basis for £199. For some owners, that might be an easier option than getting their own units reconditioned. When my own DBC6819 failed on my 4 litre, I just took it to someone who diagnosed and fixed a failed diode and rectifier pack. Much cheaper than buying a new or even recon unit.
Paul
Paul
Greg in France (08-10-2024),
Anglicomarine0326
10-28-2017 03:57 PM
jaguar_soldier
01-26-2016 12:03 PM
SPP - British
VENDOR 'For Sale' Classifieds
22
12-01-2010 01:44 AM
