'96 codes p0301, p1316
http://www.jag.co.jp/test_tool/jaguar_dtc/AJ169679.pdf
Sounds like you have a failing coil and/or spark plug at Cylinder #1 (closest to the radiator) Simple but costly fix. Make sure you purchase only coils that are made in Japan.
It'll run you about $80 and 10 minutes of your time.
King Charles
10-15-2016 07:45 AM
JimC64
03-02-2015 08:07 PM
