'96 Instrument lighting
My headlights would sometimes stop working while driving. The tail lights were not affected. Checked the headlight logic control, and that seemed to be the culprit. However, the dash lights have now quit. They will not come on with the headlights, and yes, I have tried the dimmer. All the idiot lights work. Can anyone point me in a direction?
In that case, your best bet would be to check continuity between the dash wire and the fuse….with the dimmer probably in between.
it’s not a common problem I’m afraid.
jagrepair.com will have the electrical diagrams you’ll need.
Pulling the dash out will reveal the harness you’ll need to check with your multimeter. The bunch of wiring heading into that harness, if I recall, is pretty thick, so it would probably be easier to do it that way.
While your dash is out, you can check for corrosion and might as well replace all the bulbs.
Fly Eagles Fly!
Fly Eagles Fly!
Greg in France (02-13-2023)
orangeblossom (02-24-2023)
my new one lasted from 1994-2018, but it eventually failed. Soldering points are weak and they will fail after X amounts of heat cycles.
mpasiuk
03-23-2022 01:32 PM
