96 XJS 4.0 convertible Fuel Filter Location
orangeblossom (02-10-2017)
Fuel filter location: Remove Front Drivers wheel. If you look at the wheel-less well, it will be hidden behind a plastic cover on your right hand side.
Not sure what o-rings you're looking for. I don't recall whether I ordered anything in addition to the fuel filter. If it helps I bought a Mann WK612/2 and did not record any other purchase to replace this filter.
Not sure if the fuel filter comes with them or not. I would recommend ordering the filter first and seeing if it comes with one. Maybe buy one from the dealer?
Let the forum know what you find out. I can't believe that everyone here would have re-used an ancient o-ring.
New ones have a Part Number CAC89682 but have been superseded to XR829166 and ultimately NLA, but can be found on eBay.
Orangeblossom,
You are correct if he was referring to the fuel tank connection.
His original question was "Where is the fuel filter located" and where could he purchase new O rings for the fuel lines.
He did not refer to the fuel lines leading into the fuel tank. You are correct if that is what he meant.
I also have a 96 -4Litre Conv. and just changed the fuel filter and both incoming and outgoing fuel lines are threaded!!
Softball60/Paul
Softball60/Paul
