96 xjs door lock
I have the same problem.
It's muck and grime getting into the lock mechanism and stopping the door lock from fully moving.
I try every so often some WD40 through the keyhole itself but the best way to sort it is remove the door card and thoroughly clean and grease the lock mechanism.
I think if there is the slightest amount of resistance the lock motor will not fully move.
You can normally confirm it by simply moving the door lock backwards and forwards a few times to free the mechanism up.
I do this as part of the yearly routine maintenance. My car is parked outside so needs to be done.
Anchor2 (08-26-2016)
