Wondering if anyone can verify whether the flasher relay is located under the steering wheel, behind the under dash cover?
The schematic drawing in the manual doesn't clearly show the location - it has an arrow pointing down on top of the dash. I can't imagine it's located above the steering wheel, but I've been surprised before.
I believe one of these are the flasher unit - either above or below the fuse box under the steering wheel. Have not followed the wires to confirm which yet
Then again - I have been wrong before (many times( before)
And before someone says something about the soldering effect on my main ignition switch - previous owner work
