Aav question
Aav question
Hello all, I’ve a question about the aav on my 5.3. It’s playing up and before spending I am going to follow grants advice and give it a bit of a service. I’m intending to push the bulb out using a vice and strip it that way. Question is will this do any damage to the bulb does anyone know? Also does anyone know of suppliers of new bulbs? I know a full kit is available on eBay but being from Yorkshire I’d prefer to take the cheapest option first! Thanks for your help.
Hi Brinny
When I Started '50 Shades' My Grey XJS I had a bit of the AAV Hunting Problem but having been there and done it before, I carefully removed the Rubber Elbow and then gave it a really good Squirt of WD which instantly solved the problem, as once its back in action its never gone wrong after that, so give that a try before you try anything else
The following 2 users liked this post by orangeblossom:
Grant Francis (01-21-2022),
Greg in France (01-21-2022)
Waaaaay back, the 1st one I did, I pushed the bulb out, using a small bench press, lots of care, and liquid courage, and SCREWED it.
Then the 2nd hand unit I stole to replace it, got the "cut", and the rest is very distant history.
AND
I have NEVER had a bulb not work, so I have NEVER messed with them. OK, some people claim they dont work, so maybe where you get real cold weather, and the Cat sits outside, there be a problem.
Some I have done are a tad lazy, or "slow to move", but they all work, and car has no bloody idea.
AND
orangeblossom (01-21-2022)
On mine, when I first started working on my car, it was hunting bad and the AAV was completely frozen. I had no idea what I was doing. I did a LITTLE reading (a complete novice) and I ended up using a tool to crush the bulb - hoping to get a bit more travel out of the piston. I don't think that was necessary, and after cleaning it the Grant way, and resealing, it worked and has since.
Recently I acquired a second AAV for cheap money and opened it planning to either install or have it on the shelf as spare... I cut it open to clean. This time I got a much better sense of just how much pressure/tension the top of the AAV holds in place once hot with the fairly large spring. With that understanding, this time, I used a very small set screw with a very small hole run thru the thickest part of the top hat rim into the top hat piece,,, then gooped it up (neatly) with quick dry JBWeld.
Did the same set screw thing with the one on the car just recently just in case.... I don't even KNOW (or want to) what would happen if somehow and for some reason the pressure of the spring PUSHED the top hat off the AAV while the engine was running,,, lol. That might be an adventure behind the wheel?
Anyways, that's my story, and I'm sticking to it.
The following 2 users liked this post by JayJagJay:
Hi Brinny
Why bother, as there is really nothing to Clean that some WD with the Vacuum won't shift and I've even had a Stuck AAV Start Working again after driving for just a few miles
As Grant says the Bulb can get 'Lazy' (especially in this Cold Weather) and I've never known a good o'l Squirt of WD not to put it right, as if you damage that Bulb then it is going to Cost you Megabucks to fix it
You can get one of these and rebuild it yourself. I've done it. The seller is well respected on the Jag-lovers forum.
https://www.ebay.com/itm/Jaguar-V12-...-175127-2357-0
I've had lots of debates (especially on the rennlist site) about our cars and costs and what-not, but yeah,,, I just don't like the price.
It's a lot cheaper than a new AAV. And, he might not be around forever. Everything I've gotten from him has been high quality. His prices seem reasonable, considering what his market size is, and his set up and tooling costs that he has to amortize.
My AAV was frozen. I got it freed up with some some penetrating oil and judicious prying. But it was "lazy", and wouldn't completely shut off. New parts fixed it up.
I pulled mine apart when I first got the car and cleaned and rebuilt as per Grants instructions. Mine would run at around 1500 rpm when started from cold (didn’t like that) so reassembled and pushed the top in a bit again as per Grants instructions. Now works a treat. Starting from cold 900 rpm quickly settling to 750 rpm as the engine warms up. Didn’t renew anything just rebuilt.
Rob.
Rob.
The following 2 users liked this post by Robbo D:
Rob.
Rob.
Rob.
Rob.
Somster
10-03-2013 09:50 PM
