ABS and Brake light intermit on
I recently bought this 1990 XJS sight unseen on ebay. Although in fair condition, there are some items that seem to be Jaguar typical. One concern is the brakes.
> The brake fluid looked very bad so I flushed the system by vacuuming the master cylinder and bleeding the calipers. I used fresh DOT 4. However, a before and after condition remains. When driving and using the brakes infrequently or upon first using the brakes, the ABS and BRAKE warning light will illuminate for a few seconds. If I pump the brakes the light will illuminate the first time, go out, then stay out through the pumping. Other than that, the brakes seem to work fine. I am just afraid that the ABS module may be getting flaky. What else could you suggest I look for?
innzane
09-02-2015 10:08 AM
