ABS code clearance
Hi all, got the abs light on which I believe was a faulty front sensor. Replaced the sensor and then took it for a very short run to get it over 19 mph. Can you tell me if that should clear the fault and make the light go out? Not 100% on how to clear it. Thanks once again for any help.
orangeblossom (06-05-2022)
brinny,
I assume that you ran the blink test procedure to verify that it was the sensor? If you have driven the car above 19mph, it will have erased the ABS ECM memory. Therefore, if you've still got the light, you've got an error code that's been thrown immediately since the erase cycle.
Run the blink test procedure again to see which code has been thrown.
Paul
Paul
The following 4 users liked this post by ptjs1:
92/93 XJS (06-07-2022),
Greg in France (06-06-2022),
leep123 (06-06-2022),
