Abs control module repair
i get the antilock brake warning light at 15 miles/hrs and code 1095 . Id like to pull the module to be sent out for repairs(soldering is not my specialty). Looking for recommendations . I found a company called Module Repair with a $149 service.??? Ive also read you can remove the module without the pump are there any diys on this procedure? Thank you,Jeff
There is a thread on the forum below on how to r&r the module without disconnecting all of the lines. It's for a different model Jag, but the process should be the same or similar:
https://www.jaguarforums.com/forum/x...t-44272/page2/
It's around post #25.
Jon
Jon
schuess100
10-19-2022 04:37 AM
theusualsuspect
09-02-2021 12:37 PM
