Abs problems
Hi I'm new hear. Could do with a bit of help with my 89 xjs 3.6. My car has been running for years with no problem but I came home in it last week and when I got in it again I had no brakes. No lights are showing on the dash but when you turn ignition on without starting the abs light comes on as normal and goes out as normal but the red brake light doesn't come on at all. The abs pump doesn't run either. I have put power to the pump and I know this still works. I have also changed the yellow and relay and still nothing. I also checked for power in the wire powering the pump which shows no power. Does anybody have any advice thanks.
