ABS pump runs all the time (1989 XJS)
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Read all the threads before posting this one. My problem is slightly different. The ABS pump on my 1989 XJS runs constantly whenever the ignition is switched on. It does not cycle. Depressing and or pumping the brake pedal has no effect on the pump and also there is no braking action. The car sat for six years in my garage prior to my "reactivating" it. Also, during this instance, I removed the ABS pump assembly to gain access to the firewall. In the process (besides disconnecting the two electrical plugs) I had to disconnect the supply and feed lines. Could breaking the integrity of the lines have caused my problem or the six year dormant period (or a combination of both)? Any suggestions on how to proceed???
![](https://www.jaguarforums.com/forum/attachments/xjs-x27-32/27818-abs-pump-runs-all-time-1989-xjs-quote.gif?dateline=1355431353)
I posted a response in the ABS pump problems thread so here it is
You will need to bleed the ABS accumulator.
Also if you allow the pump to continue to run you will damage it. The manual specifically warns not to let the pump run for more than 2min or the motor will overheat - if this happens the manual states to allow the motor to cool for at least 10min.
I have a full write up on how to bleed the ABS system here
http://warrjon.blogspot.com.au/p/how...teves-abs.html
Hope this helps. Feel free to ask any questions.
I can vouch for that. Even with a non-working ABS pump, you will have brakes. You will have to hold the steering wheel with both hands and pretend you are leg-pressing an elephant, and only the front brakes will work, but you will have brakes.
Are you in Texas by any chance? I know someone by that name who lives in Texas.
It has something to do with the way Jaguar designed the brakes. Instead of using something like a vacuum assist (like the rest of the world), Jaguar uses the pressure generated from the pump to BOTH give you power brakes AND operate the ABS. In the event, though, that you loose a pump (can something break on a Jaguar?) You still need to be able to stop. For some reason, they only put the pass-through on the front brakes.
Received 10,880 Likes
Right!
But Jaguar's model year designations for USA cars versus ROW cars can be confusing and often appears irrational.
nofking (01-11-2013)
BrentGardner
28
04-26-2024 03:08 AM
FS[NorthEast]: 1991 xjs v12
DrScientist
12-09-2015 07:36 PM
