AC Climate Control Panel Fuse (1994 XJS)
After searching all day, I give up!
Can anyone tell me where the fuse is for the lighting (bulbs) in the AC Climate Control Panel (that surrounds the radio) on a 94 XJS? The panel itself works but the illumination stopped after I, like a fool tried to tighten one of the bulbs while the ignition was on. Im certain I blew the fuse as I saw a spark.
I have searched everywhere with no luck including the factory electrical manual.
Any help much appreciated.
Richard
Richard
SOLVED:
When I shorted out the bulb, it burned out "something" in the climate control plugin that the climate control panel plugs into. Luckily, I had a spare. The bulbs now work on the panel. I do not think there is a fuse. It is very stupid for Jaguar not have it fused.
1995 might be different from 94 but I looked into my plug I don't see anything burnt.
I had to replace the "AC Panel Control Interface Module" which is behind the control panel. I am attaching mine with the note I wrote on it. There is one currently on EBay for $29.99. Hope this helps! It was one of the most frustrating things I had done working on my cars!
https://www.ebay.com/p/2194570448
Good luck!
Richard
Good luck!
Richard
Good luck!
Richard
Good luck!
Richard
Looks like the center console has to come off to remove, I had pushed it back a bit and the module came out.
I do see a burnt resistor, I am going to replace it and as a backup buy from eBay.
Sounds excellent! Could you shoot some pics of the burnt resistor, part, and replacement? I could possibly save my damaged one. My email:
benzjag@hotmail.com
Richard
benzjag@hotmail.com
Richard
