AC Compressor Wiring Mystery
Old 05-06-2022 | 06:19 PM
DaveAllen's Avatar
Default AC Compressor Wiring Mystery
My AC compressor has stopped working recently. I'm currently checking the wiring of my compressor and came across this. Does any one know what this device is in the AC Compressor clutch wiring?
The green wire is the +12V to the compressor clutch and the black wire goes to the switch at the rear of the compressor. The mystery device seems to connect the +ve and -ve connections to the AC compressor clutch.
My XJ-S is a US Spec from January 1987 and has the Delanair Mk III computerized climate control system.
Thanks in advance! Dave
Old 05-06-2022 | 07:01 PM
jal1234's Avatar
Its the superheat switch, essentially a fuse, to protect the compressor if system pressures go out of range. Its function is in The BOOK, by Kirby Palm.
Old 05-06-2022 | 08:21 PM
DaveAllen's Avatar
Thank you. So that what it looks like! I've got the book, but sometimes I need a picture!
Much appreciated!
Cheers! Dave
Old 05-06-2022 | 10:00 PM
Doug's Avatar
The device in the wiring is a diode and a resistor.
The superheat switch, when fitted, actually mounts into the end plate of the a/c compressor. Only early Del III cars used the superheat switch. Most used an HSLP switch (High Side Low Pressure).
Cars with the superheat switch used a three-prong thermal limiter fuse (see picture) in the circuit which will blow if the system is low on freon. This prevents compressor damage. There is no such fuse on systems that use the HSLP switch.
Old 05-07-2022 | 07:09 AM
jal1234's Avatar
The OPs picture is of the thermal limiting fuse. Its part of the Superheat system. You are correct in that the thing that blows the fuse is in the end of the compressor.
Old 05-07-2022 | 11:33 AM
DaveAllen's Avatar
Thank you for the insight! Attached is a picture of the rear of the compressor (cruise control module removed for a better view). I don't see anything three-pronged, and I'm wondering if my car has the HSLP fitted to the compressor and remnants of the super heat system in the wiring loom. Previous maintenance perhaps?
Cheers, Dave
Old 05-07-2022 | 11:45 AM
jal1234's Avatar
The switch itself is under the white cap at the bottom of the compressor in the picture. It is a single pole switch. If it closes, it blows the fuse in the three prong thermal fuse.
The later pressure switch is a much better arrangement. When i converted my 87 to a Sanden compressor and R134a, I went to pressure switch system.
Old 05-07-2022 | 12:06 PM
Doug's Avatar
Visually the difference between a Superheat switch and an HSLP switch is very subtle. You'd need to have one of each side by side, IMO, to tell. And the compressors are unique as to which type of switch is used. That is, you can't use a superheat switch in a compressor designed for an HSLP switch, and vice versa.
This illustration shows how the three-prong thermal limiter is fitted
One problem is that the thermal limiter fuses are often simply eliminated from the circuit. Thus, not seeing one isn't absolute proof that you have an HSLP system.
However, FWIW, my Feb '87 build XJS had the HSLP system (VIN 139xxx).
In any case.....my S57 diagrams show a green/brown to power-up the compressor clutch. Are you getting 12v there?
Old 05-07-2022 | 03:17 PM
DaveAllen's Avatar
My switch at the rear of the compressor is wire directly to the compressor clutch connector, without any three prong device. There is no bracket at the front of the compressor either. Again not definitive because somebody could have been in there in the past.
I do get 12V at the green / brown wire at the clutch, but if I measure across the +ve and -ve terminals I get around 3 volts only. Not enough to engage the clutch. Maybe the resistor / diode device in my first picture is providing a by-pass circuit to ground, leaving insufficient voltage to engage the clutch?
I think the original mystery device looks like a home made effort to mimic some of the function of the thermal limiter, because its not like the circuit diagram. It does look like I could remove it if I replaced the compressor with a HSLP switch (which I think is the only type now available.)
Thanks, Dave
Old 05-07-2022 | 04:00 PM
Doug's Avatar
What you have looks the same as what I have on my '88 V12.
The a/c harness diode is not documented in any of the Jaguar diagrams I've seen...but they're there
I'd take it apart/unwrap it and see what's there with my own two eyes. If you see a diode, and I suspect you will, it's easily tested and replaced
Old 05-08-2022 | 07:07 PM
DaveAllen's Avatar
Doug - Thank you for the confirmation that my "mystery item" might be a an undocumented factory item. I will test it after disconnecting from the harness. I've read somewhere that voltage applied in the wrong place can damage the AC computer.
Cheers, Dave
sanchez
XJ40 ( XJ81 )
09-20-2018 04:51 PM
Vee
05-16-2018 08:34 PM
TheWarlock
09-07-2015 09:30 PM
avioni
06-02-2013 08:06 AM
Bauldee
08-14-2009 05:06 PM
Quick Reply: AC Compressor Wiring Mystery
