Ac controls / wiring diagrams 1996 xjs
Old 02-21-2019 | 12:48 PM
louiedog's Avatar
Default Ac controls / wiring diagrams 1996 xjs
Ac fans run on after the ignition is in off position. LH runs at low speed while RH runs at high speed. Can anyone help with info or a link to wiring schematics?
Old 02-21-2019 | 02:47 PM
jimbov8's Avatar
Try jagrepair.com. Lots of free to download manuals available.
Old 02-26-2019 | 12:48 PM
louiedog's Avatar
Default jagrepair
Thank you, i'll see if they can help me.
Old 02-26-2019 | 12:53 PM
Jagboi64's Avatar
The high speed is probably the high speed relay sticking closed, and the low speed is the darlington transistor in the variable speed control circuit failing. Both items are inside the blower housing and require removal of the housings to get to them.
Old 02-26-2019 | 03:05 PM
warrjon's Avatar
Both failures will most likely be the darlington transistor, the one running fast the trans will be short and the one running slow the trans will be leaking.
Here is a circuit diagram I made when I repaired mine. You can repair it yourself. You will need a good soldering iron as the ground plane on the PCB is large and a small iron will struggle to melt the solder.
Challenger
08-09-2015 04:30 PM
Razkid
09-29-2013 08:37 AM
Bmxjeff
10-27-2010 10:51 PM
ShadyJC
06-28-2010 11:05 PM
m0t0rm0uth
General Tech Help
01-24-2010 10:18 AM
Quick Reply: Ac controls / wiring diagrams 1996 xjs
