AC Delco window motor on XJS?
AC delco motors only until the mid 80's. Around 1988 the Window motors change to square Brose style which are very common and can be found in Delco Boxes. This is kind'a common for example,my Porsche 928 used a SAAB window motor which can be had for far less money and also uses a Brose style motor
Received 10,979 Likes
I think 1974- 1984 were round bodied Delco, after that was Brose. I just pulled some out of a 1981 XJ6 last week and they are stamped Delco.
Prior to 1974, they were the square bodied Delcos as used in GM cars up to about 1976.
The square and round are wired differently, the square are case grounded, the round ( and Brose) are not - they change direction by swapping the positive and negative. The square have ground at the case, and change direction by applying power to different terminals.
The bolt pattern also changed between Delco and Brose, so they are not interchangable
AC Delco wasn't associated with only GM cars. Heck, from time to time you can even find Fords with parts stamped AC Delco. . I'm certain that I've see various Euro cars with some AC Delco items....but the details escape me at the moment.
Greg in France (05-01-2022)
Blue Lion
16
06-17-2011 07:27 AM
