ac not working
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/file_81949b8f7cb9bbdadfdca338c9f84a38482b94c2.jpeg)
i have a 1988 jaguar xjs. when i bought it, the a/c is working perfectly. I brought it to jaguar specialist to get tune up. after the tune up, they told me that the a/c is not working. I checked it and the ac clutch is not engaging. I checked the fuse(25 amps) and replaced it to make sure. I took the reading using a gauge and it reads 85 psi(its high because the compressor is not running). I was reading some of the thread and someone mentioned that there is a fuse between inlet and outlet that i need to check. i tried to look for it but i cannot find it. I also noticed that theres a wire from the compressor that is not hooked up to anything(see picture. the wire at the left is from the ac compressor. I dont know what wire is on the right side). Can someone help me troubleshoot this.The shop told me that they can retrofit my system. I told them that theres nothing wrong with the system before i brought it to them. what is the fuse between inlet and outlet looked like ?
Received 10,872 Likes
Are both disconnected wires green/white? That would be correct for the compressor circuit.
If so, connect them together and report back.
Not sure about a fuse "....between the inlet and outlet...". Inlet and outlet of.....what? Some used a three-prong "thermal fuse" which is mounted right next to the compressor....but your '88 shouldn't have it. Different circuitry.
Romel420 (08-06-2018)
Romel420 (08-07-2018)
In the manual, it talks about a low pressure switch which cuts off the a/c automatically until reset by a mechanic. Does anyone know where this switch is so I can do this myself, or has anyone else experienced this problem?
Mine leaking freon so I unpluged a wire to compressor and it stopped it from engaging, will look tomorrow and take pic.Sounds like they did something to charge you more $. I have not trusted dealer, mechanics in a long time.
Honey, that new mink coat you wanted just drove into the shop. LOL
Get a battery, put direct 12 V to both Terminals on the magnetic clutch of the AC. If you look at the compressor, you'll see a black plastic plug at around 2 o clock when looking from the front of the car. Otherwise about 10 o clock. Take that plug off and you'll find the terminals. 12 V applied, doesn't matter which side is which, as the magnetic field doesn't change polerisation, and ypu should hear it CLACK if it works. Can be a burn out coil though. It does happen.
Romel420 (08-13-2018)
The following 2 users liked this post by Romel420:
Greg in France (08-14-2018),
v1rok (08-13-2018)
Martyn Musch
07-24-2023 04:01 PM
cleve
07-22-2020 05:15 AM
Bluecortina76
09-15-2017 01:52 PM
M12345678
07-14-2016 12:49 PM
denisecdb
04-10-2012 11:08 PM
