Acceleration hesitation (or choke?)
Greetings!
my car misbehaves lately, when I give it some gas it looses power for a split second before starting to accelerate. When driving it makes unpleasant 'jerk' in the drivetrain, pretty annoying...
When car idles, if I stay on top of the engine and pull the throttle cable - loss of power is accompanied by a vacuum 'hiss'... then engine revs.
Tried to disconnect vacuum line from distributor - no difference(yet vacuum is delivered to distributor when I pull throttle cable as expected). Checked timing with strobe - about 18deg as expected.
I replaced spark plugs yesterday(not because I thought it will fix the problem), they were on 'white color' side, like engine is running lean.
I suspect the problem started after I took car for tune-up to reduce slightly elevated CO level.
Any ideas where I should look for the problem?
Thank you.
Thank you.
I had the car for a while now and replaced few parts, but problem is still there. Here is some more info about it, maybe someone will spot the offending unit now.
To start with I have idle problem, when car is cold it is high. I can bring it down using air bypass screw but when car is hot - it drop so much that car stalls. It also floats (like the car is alive) all of a sudden it shoots up. Can someone refer to the proper procedure of setting idle? I've heard there is an adjustment on ECU for idle - is that true?
Another problem: when car is hot and I accelerate - car is kinda 'coughing and sneezing' for period of few moments to few seconds and then it picks up. Once it picks-up it runs pretty smooth. When I first start it(cold) it runs fine.
I replaced TPS - no change (well, there is a change, throttle is a bit smoother, but not to this behavior).
Wanted to replace oxygen sensor, but could not find it. Manual I have said it should have one, but it's not there. I have AKM 9063 manual, I guess I need 'earlier' version. I believe earlier cars did not have oxygen sensors.
I am planning to replace coolant temperature sensor next, as it seem very important as if I unplug it - car dies ( in contrast if I unplug air temp sensor - no change at all).
Anyone have suggestions how to fix these problems?
Thank you.
Thank you.
Well, today I caught my car loosing power again, this time during idle.
By disconnecting spark plugs one-by-one I found the issue - 3 cylinders (4-6) are not firing! (I have total of 6, 3.6L model) I replaced first three plugs with last three - same thing. Checked for spark - sparks are flying in back cylinders wires. Then I was disconnecting injectors and here it is - injectors 3 -6 are not injecting! What is strange is that this problem was intermittent for a while.
I doubt that all 3 injectors stick together by accident, it must be some common fuse or something of that sort. Anyone knows the cure? Please save me from digging-up and tracing electrical schema :-)
jetjack
04-11-2016 02:46 AM
