Accumulator pump motor removal
This is my first time on here and my first post. If I'm not doing this correctly, please say so.
I am getting ready to remove the motor from the accumulator pump on a '88 XJS.
It appears to me that when I do this it will drain all the brake fluid from the reservoir because of the seal on the motor shaft. Am I correct or not?
Any tips on doing this are appreciated.
Thanks,
Sam
Thanks,
Sam
Thank you for your advise. I do have the four shop manuals. Have also found that a 4mm Allen wrench will loosen the two motor holding screws.
One more question, please? In the shop manual it appears that the motor shaft is just notched into the pump ecventric rotor. Do you know if this is true, or is the shaft screwed or clipped someway to the pump rotor?
Thanks, again, for the contact.
Sam
Sam
Sam
Sam
Good luck!
Sam-Tx (11-08-2012)
Thanks for all your advise. Here is an update after today: motor is fine; pump is locked solid! Whole system seems full of mud! (Brake fluid and dirt, I'm guessing.)
Disassembly was fairly easy and I know to get new o-rings before I go back with it.
Going to try soaking the pump in denatured alcohol for a day or so, hoping to get it freed up so I can flush it.
Will have to have entire brake system totally flushed.
Would prefer to buy a full new unit but having a problem finding one.
Why won't a '90 model system that looks identical in every way work on a late '88 model?
Any thoughts appreciated.
Thanks,
Sam
Thanks,
Sam
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
