Adding and electric fan to assist the AC.
I know how the system works. A fan in front of the condenser helps keeps engine temps stay cool though, while the AC load is on. I got my fan working via a switch and it makes a huge difference to the engine temp. The AC cooling portion is not dependent of the aux fan. Its 104deg at the moment and the interior is much cooler when Im not stressing about engine temps😆
Greg in France (08-28-2020)
Your A/C system works on pressure in the Freon not the temperature of your engine. You already have an engine temperature thermo switch that controls an AUX fan which helps cool the engine Not the Freon A/C. Adding another fan has no bearing on the A/C temp settings. The higher ambient temperature around your vehicle is what causes the A/C to work harder and you have no control of that.
The following 2 users liked this post by Greg in France:
Doug (08-28-2020),
Grant Francis (08-28-2020)
Received 10,979 Likes
More airflow thru the condenser can improve A/C performance. That doesn't mean it necessarily will improve A/C performance. Depends on various.....variables . Some cars have a fan specifically identified as a "condenser fan".
Some cars (including some Jags) have the aux fan kick in whenever the compressor is engaged, regardless of engine temp. Others have a circuit that engages an aux fan when freon pressure reaches xxx-level. Other have nothing at all.
Condenser size and design, and the amount of air provided by the main fan, surely enter in to the equation....among other things that are beyond my dimensions of comprehension.
Vidsquad
07-04-2014 07:35 AM
