Adding led strips to rear early tail lights
I've been totally going overboard with my 1988 XJS since I had her changed from signal red (three in town) to piano black. It set me off on a quest to make mine as unique as possible. I've already done this to my 2010 XF to great success. So now it's the old girls turn.
I've decided the tail lights are so interesting with their arched shape, I'm going to add led red strips inside to accentuate the arch. Was hoping I could simply use the interior to self stick the strip to but as with every single thing on these cars, they were not so straight forwardly designed. There's really no edge to apply the strip to so I'm cutting a clear plexi outline of the arch that I can attach the strip to then hopefully mount in front of the brake light using spacers and long bolts. Only question is whether to use them as brake lights (still having standard bulb in conjunction) or simply driving lights. Probably the later.
Wish me luck!!
I've already added brilliant interior amber accent lighting. Foot wells, ski slope illumination, and soon soft door panel lighting. All concealed and just that warm glow.
Wish me luck!!
Wouldn't be the first time I've tried a mod and thought better after installed!
I will say the halo replacement quad headlamp bulbs from eBay do look quite good!
The interior lighting was so easy though. Especially if you pull power from the lighter bulb. I didn't even splice into the wires. I simply pushed a wire into the terminals that plug into the lighter bulb and used it to wire led strips. Easy removal if any future problems.
If you go to my albums in my profile, you'll see my xf. I'm working on downloading pics to a URL site. I really wish I could download directly from phone or pc and not have to go through a third party URL site!
On my XF I've totally blacked out all chrome ant entire roof, added the drl blades in lower front air intakes, added a new German made leaper, also paino black and a totally custom rear badge using a 3" round red led marker with the growler chrome portions from new badge. Currently it's wired to parking lights but I'm planning to wire to brake lights. Also just added black side vents and planning on , now, having all black trim wrapped in translucent black carbon fiber!
I've since changed to Euro hedlamps. Actually bought two sets as the first set had no silver inside and a chip on the interior of the glass as well. I've separated the glass from the housing and sprayed with bumper chrome. When I tested them, they really looked great. As usual, I'm playing around with trying led white strips inside the housing to see what intergrated DRL light strips would look like inside the euro headlamp. they actually look good! I just want longer strips to outline the outer edges and bottom of the glass to give a "J" light pattern, all inside the headlamp.
I did order an extra set of quad surrounds that were already painted black. Didn't care for them as much, made the car look a bit to "Christine" for me. Frankly, the quad headlights even with chrome made me think about that darn movie too much, hence the swap to Euro.
innzane
09-02-2015 10:08 AM
